Size of spanner
Machra
Size of spanner
Post by Machra » 19 Nov 2001, 17:04
What size of spanner do I need to undo the hydro pipes on my xantia. 7mm is small 8mm is big and I dont think they make 1/2 sizes. Is it a special Citroen size?
Dave Burns
Post by Dave Burns » 20 Nov 2001, 04:06
They should be 8mm though they can go slightly undersize due to corrosion, if so try 5/16 AF this is slightly down on 8mm, a better idea would be to invest in a set of flared nut spanners rather than use plain open ended ones, they are less likely to damage the nut.
Good luck
Dave
