Not sure there are any sites on the web, I use works computer (work at garage) to get the vin numbers which is needed to use http://service.citroen.com/" onclick="window.open(this.href);return false;
Free to use some of the site once registered, not sure but you may need a valid VAT number.
info from a reg
- waynedance
- x 8
Re: info from a reg
Volvo S80 D5.........
- waynedance
- x 8
Re: info from a reg
Vehicle characteristics y366vos
Vehicle family BERLINGO
AS RPO No 08862 FV 1 0692
Warranty Start Date 06/03/2001
OPB 102I
BER e2*98/14*0225*00
General information
PRODUCT TYPE UTILITY VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY BERLINGO
SILHOUETTE ESTATE VAN
TRIM LEVEL MULTISPACE SLIDING SIDE DOOR
ENGINE INJECTION TU3JP
TRANSMISSION BVM5
INTERIOR TRIM TYPE SARGA CLOTH "EV"
UPHOLSTERY COLOUR "FR"
GEARBOX (CHARACTERISTICS) UP-RATED MA
ENGINE (TYPE) TU/TUD
OTHER BADGE WITHOUT FULLER BADGE
OTHER BADGE, " MISC. " MULTISPACE
STEERING POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 21X18
Fuel supply-Engine
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
FUEL SUPPLY IMPROVEMENT W/O PETROL FEED IMPROVEMENT
COOLING MOTOR RADIATOR TH : 23 DM2 (23 TR)
POWER VARIATION (ENGINE) STANDARD POWER
REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITH ACCELEROMETER
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
FAN 1 FAN , 1 RATE
FUEL VAPOUR RETRIEVAL NON CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING SAGEM
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 13 X 59
WHEEL STYLE BLACK 14 INCH STEEL WHEEL
SEAL, WHEEL END WHEEL-SIDE JOINT AC2000I
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT GI2000I
DIFFERENTIAL (GEARBOX) STD IMP GEARBOX DIFF
TYRE (SIZE, TYPE) TYRE 175/70 R14 T NON-REINFORCED
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE MA
Suspension-Steering-Brakes
ABS W/O ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 21
BRAKE TYPE NON-VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
BRAKE ASSOCIATED VARIANT WITHOUT ABS
Body fittings
TOWBAR WITHOUT TOWBAR
SIDE MOULDINGS (TYPE) GREY DYED SIDELAMPS WIDTH = 75
WHEEL EMBELLISHER (STYLE) ST MALO STYLE 6 HOLES 14 INCHES
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
REAR ROOF FLAP W/O ROOF TRAP
SIDE LOAD DOOR SLIDING RH LH SIDE DOOR
BUMPER TWO TONE BUMPER
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP NO FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR MN INT CTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES C HANDLES/MIRRORS C PLATE LIGHTING C BOOT PROTECT
SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER
SUN ROOF FIXED ROOF
HOOD COLOUR WITHOUT HOOD
BUMPER TRIM BUMPER WITHOUT CHROME INSERT
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
WINDOW (TYPE) NON ATHERMAL WINDSCREEN
SIDE WINDOW (COMM. VEH. ONLY) 2 HALF-OPENING WINDOWS EACH SIDE
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVER WITH LUGGAGE COVER
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING WITH AIR RECYCLING
SPEED GRADUATIONS GRADUATION MPH
TACHOMETER REV COUNTER WITH NEEDLE
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM RUBBER MAT LEV C
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION MAXI 180 K/H OR 110 M/H DIALS BLUE
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
LOUDSPEAKER ASSEMBLY WITH 2 FRONT SPEAKERS + 2 REAR SPEAKERS
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
DRIVER’S SEAT FOLDING WITH FOLD DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING WITH FOLD PASS FRONT SEATING
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
CLOCK NUMERIC CLOCK
COURTESY MIRROR PASSENGER SIDE WITHOUT LIGHTING
OIL GAUGE W/O OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
PASSENGER AIRBAG NO PASSENGER AIRBAG
AIRBAG DEACTIVATION WITHOUT AIRBAG DEACTIVATION
REAR MOVING PANEL REAR WINDOW
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
RADIO RECEIVER "RB1" RDS CASSETTE AUDIO SYSTEM
REFRIGERATION WITHOUT AIR CONDITIONING
DRIVER AIRBAG DRIVERS AIR BAG
CARPET DILOURS CARPET F330
SWITCH ELECTRONIC ANTI-THEFT KEY
WATER TEMP INDICATOR WATER TEMP INDIC +RED TELLTALE
FLEXIBLE HEAT PARTITION W/O SUPPLE THERMIC PANEL
LOCKING CONTROL SIMPLE CENTRAL LOCKING
FAN 1 FAN , 1 RATE
Electrical
ALTERNATOR ALTERNATOR 70 AMP
BATTERY (TYPE) MAINTAINANCE-FREE BATTERY
BATTERY BATTERY LO 200
STARTER MOTOR CLASS 1 STARTER MOTOR
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
CENTRAL LOCKING CONTROL CENTR LOCK SYSTM DRIVER’SIDE
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
ADDITIONAL TYPE APPROVAL PLATE W/O ADDIT HOMOLOGATION PLATE
SLAVE CONTROL UNIT BUILT-IN SYSTEMS INTERFACE (BSI)
OPB 102I
General information
TRANSMISSION BVM5
Fuel supply-Engine
FAN 1 FAN , 1 RATE
Gearbox-Driveshafts
TRANSMISSION BVM5
GEARBOX TYPE MA
ABS W/O ABS BRAKES
Body fittings
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
FAN 1 FAN , 1 RATE
Electrical
Miscellaneous
Re: info from a reg
im already registered on service citroen and pug service box have bin for years even when it was called PR.net,waynedance wrote:Not sure there are any sites on the web, I use works computer (work at garage) to get the vin numbers which is needed to use http://service.citroen.com/" onclick="window.open(this.href);return false;
i was thinking for general use on other crap besides PSA cars
Regards, malcolm.
Re: info from a reg
CJZ 1226. It's a NI plate so may not be on the system...
