Xantia Key Fob Programing
Can i use a second hand key fob and can it be reprogrammed? my remote locking used to work but no longer and second hand key should be cheap fix if it works.
Citroën Xantia 75th Anniversary Limited Edition
Re: Xantia Key Fob Programing
Series 1 infrared remote ? Yes you can definitely reprogram a 2nd hand remote for you car, and you don't need anything special like a Lexia to program it.
Series 2 RF remote ? Maybe, maybe not. The C5 RF remotes can't be reprogrammed to another car but I have not seen a definitive answer to whether a Series 2 Xantia RF remote can be. If it is possible it will require Lexia access as there is a remote programming procedure in the Lexia.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- My Cars: Xantia Exclusive 110Hdi Estate 1999
Xantia Series 2 RF remotes can be reprogrammed using a Lexia, I have reprogrammed a 2nd hand one to my car very successfully.
Thanks for the info, I'll get one end give it a go. Oh, and it's a S2. So I'll have to find someone with a Lexia.
