This is used extensively where jubilee clips might have been used in the past. In a Citroen context it is usually referred to as Ligarex strapping, and armed with a special Ligarex strapping tool, lots of strapping can be done.
Is Ligarex strapping the best or are there other forms/ makes which are cheaper/ better?
Where does one buy strapping and more particularly the strapping tool.
By "where" I also mean, convenient, most competitive, treat customers reasonably etc.
Metal strapping
Ligarex strapping and the tool, clips etc can be bought from GSF Car Parts
N99190 Ligarex Starter pack (pliers, clips, 25m strapping etc) £28.00
N99192 Plastic dispenser roll for strapping £14.00
N99194 Pack 100 Clips £2.80
N99195 25m stainless steel strapping £10.50
N99196 Ligarex pliers £22.00
As you can see the best plan is probably to buy a starter pack.
Although primarily used for securing driveshaft gaiters, Ligerx has a variety of automotive and domestic securing applications due to its resistance to heat and corrosion.
