Hi all,
I'm changing the cambelt over the weekend and am undecided as to exactly which I should buy.
Do people use Andyspares for such an item or is it still preferred to go main dealer?
Also, would I be best advised to fit a new Timing belt tensioner at the same time, or is this not necessary.
Which timing belt should I buy from GSF for a 93 BX 17 TZD Turbo?
There seems to be 2 belts available and I'm not sure which to go for...If any?
Thanks in advance
Bryn
Cambelt
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Although during the time I had my BXTZD I fitted three cambelts to it, I didn't need to replace the tensioner up to the time I sold the vehicle on to another member of this forum. When you have the belt removed give the pulleys a spin and if you detect any roughness in the running, then is the time to change it. Also look closely at the water pump pulley for signs of leakage or undue movement.
