Half Shaft Bearing ...
Post Reply
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Hi peoples,
Is it possible and how possible is it to renew the Half Shaft bearing on the drivers side Drive shaft where it passes through the lower engine mount??
A very sad...
1994 XM 2.1 d auto
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 994
Re: Half Shaft Bearing ...
Post by RichardW »
Just the same as renewing any other bearing, Paul - you just need a puller with loooooooooong legs :lol: It tells you in the BOL how to do it - page 8.6 in my Xantia version
citroenxm
x 71
Post by citroenxm »
Thanks richard,
Anyone know the bearing spec? Ooo Ill have a look on service citroen to see if I can see what size it is...
The shaft is for a HDi 110..
35x62 - 16 bearing is on service Citroen....
Ebay only have 35x62 - 14 or 18... typical!
A very sad...
1994 XM 2.1 d auto
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6175
Contact:
Post by CitroJim »
Paul, as long as the dimensions are right then the number of balls is not critical - the more the more load the bearing can take..
Or do is the 14, 16 and 18 refer to the width?
If so then one a bit thinner or thicker will be OK as the hockey sticks will be able to accommodate it. If the housing can take the slightly thicker one than go for that one.
Make sure too the bearing you buy is a shielded one. Open balls will be no good at all as the grease will go in no time to be replaced by wet crud...
citroenxm
x 71
Post by citroenxm »
Ahhh thats what the third number is for.... number of balls..
Right.. so just the 35x62 is the important things...
Will THIS BEARING do ok then??
Thanks Jim.
A very sad...
1994 XM 2.1 d auto
x 6175
Contact:
Post by CitroJim »
There'll be three critical dimensions Paul, Internal diameter, external diameter and width.
If you look at the old bearing closely there may be a number on it which identifies it and that may help source a replacement. Normally all these sort of bearings are pretty standard so the dimensions and the identifying number should allow you to find a generic replacement for it...
I've seen websites in the past that specialise in bearings and oil seals. One such should be able to supply. This one is a typical sort of one...
citroenxm
x 71
Post by citroenxm »
the size I got above was off Service Citroen, for a 2001 Y reg HDi drive shaft.. The bearing is still Stealer available...
A very sad...
1994 XM 2.1 d auto
My Cars:
x 92
Post by citronut »
the third dimension is bearing tickness nout to do with a load of balls :roll: :shock: :wink: ,
i would think as long as the hockey stick bolts will clamp the bearing, it wont matter within reason the thickness of the bearing,
dont you have a bearing stockist in the ooop thur in the wooly wilds then Paul
Regards, malcolm.
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2507
Post by Gibbo2286 »
Cheap and overnight delivery from here: http://ptandbearings.co.uk/" onclick="window.open(this.href);return false; Just give them the number off the bearing and they'll match it/.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Paul, you'll want a press-on collar as well, assuming you swell the old one with a cold chisel to remove.
Post Reply
