I've just had the fore-aft gearchange rod fail on my BX. From a quick look on the forum, this seems to be quite common and mine failed where they usually do - the forward (gearbox end) balljoint socket.
I think Citroen call this rod the "lower" one - it's the long, longitudinal rod that has a balljoint at each end and runs from the bottom of the gearstick to the gearbox.
My local Citroen dealer gave me a part number of 95495340. I later found a dealer who had one in stock, and got it sent - after they confirmed that this is the correct part no.
Of course it isn't the right part at all...
Mine is about an inch longer and includes a bend - which really is necessary. It also includes a rubber collar, just to the rear of the bend.
95495340 is dead straight, is made from smaller diameter tube and has no rubber collar. I suspect that it's for a BX14.
As I'm now sure that 95495340 is not the right part for my car, does anyone know what the correct part number is, please?
Or, even better, know where I can get hold of the correct rod?
Thanks,
Jim.
BX - gearchange rod part no, please!
'88 BX 19 GTi, 94000 miles
'96 Laguna RXE Family, 175000 miles
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: BX - gearchange rod part no, please!
Hi Jim,
Looking at Citroen Service, it looks like its 95 495 341 .... This shows a Kink in the Rod... Looks like all XU engines use this one, and the 340 one you got is for 1360cc TU engines only.
You may have a job though, like all BX stuff, it is now showing NFP on the Service site..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Thanks for the information!
Update...
I've spoken to a few people this morning, the consensus is that the part I want is 96071597 - which is still available (although on back order until a bit later in the month).
The picture the dealer sent me seems about right - there is a (small) bend shown, and what looks like a collar, too.
Before I go ahead and order it up (I mean pay for it up front, really), can anyone confirm that this is actually what I'm looking for?
Thanks again,
Jim.
Thanks again,
Jim.
here is price and part No. if its still available
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
96071597 GEARSHIFT BAR 42.28 GBP 50.74 GBP 50.74 GBP
and here are the dimensions
GEARSHIFT BAR
DIAM 13 LON 680,3
GEARSHIFT BAR
DIAM 13 LON 680,3
Regards, malcolm.
Thanks for the response Malcolm!
That sounds about what the Citroen dealers have been telling me today.
The only problem I've got is with the dimensions - my old rod (which is now off the car) is approx. 702mm long and 17mm diameter - balljoint socket centres are roughly 685mm. Whilst the ...340 that I was supplied with last week is approx. 683 long and 12mm diameter.
It isn't possible, is it, that ...597 is simply a replacement for ...340 ?
Jim.
Jim.
