Penetrating Oil Advice
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Hi all..
Advice on the best Penertraiting oil OTHER THEN WD40...
The issue we have is a partially siezed Steering UJ joint on an XM, but rather remove it, which is a bit more fiddley then a Xantia, try and inialate it in penetrating oil in a hope to free it, then coat it in grease..
So any recomends on an oil???
Cheers
Cheers
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Re: Penetrating Oil Advice
Not an oil, (in fact it's non oil based and non greasy) but when it comes to penetrating and freeing rusted bolts and mechanisms etc you won't find much better than this:
http://www.lpslabs.com/product_pg/lubri ... /LPS1.html" onclick="window.open(this.href);return false;
Only trouble is I'm not sure if its readily available in the UK, I still have a can I brought with me from New Zealand I guess I will find out soon as my can is nearly empty...
Edit: There is also an oily version of it that leaves an oily protective residue, although I haven't used that one much:
http://www.lpslabs.com/product_pg/lubri ... /LPS2.html" onclick="window.open(this.href);return false;
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Cheers, its not for rusted bolts, its for UJ spindle joints that tend it sieze over long time...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Citroening
- My Cars: Various Makes/Models Nowadays...
- x 19
This Deblock Oil is the best we've ever had Paul:
http://www.innotecworld.com/products/gr ... oductid=84" onclick="window.open(this.href);return false;
Innotec do some great stuff - their double sided tape is second to none and perfect for if you're, eg, sticking side mouldings on cars etc. THE best...
Franklin
- My Cars: 2001 Xantia 110 Hdi Forte estate - owned from new.
1984 2cv Special
Various modern crap!
Plus Gas? Was all the trade ever used, a few years ago?
plus gas is the pups nuts, wd40 is utterly useless as a penetrating oil, or anything really.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Plus gas available in a spray canister though?? I can squirt a can of Plug gas from the wheel arch.. Ill need to reach into the UJ, which on the XM is not as easy as the Xantia, so If its available in a pressurised can that would be good...Deanxm wrote:plus gas is the pups nuts, wd40 is utterly useless as a penetrating oil, or anything really.
D
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- gadgetgricey
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
There is the answer , plus gas the hell out of it then drown it in engine oil or 3 in 1, grease wont be much cop, it will just sit on the outside of the joint and attract muck.
D
XM Prestige PRV6 92
Ah, I guessed the Grease would hold in the the plus gas or what ever, and hold out any dampness etc...
Thanks people... And Dave!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Würth Rost-Off, but you'll have to speak to some one in the trade as Würth don't do retail.
Citroën Xantia 75th Anniversary Limited Edition
diesel is a good penetrating fluid also,
Regards, malcolm.
- uhn113x
- My Cars: 1981 Dyane - on road all year round.
1982 GSA Pallas - on road April - September.
1997 ZX 1.9D Dimension. - x 1
WD40 isn't a penetrating oil and neither does it purport to be.
Equal parts of DERV, paraffin and LHM?
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
its not even and oil it a moisture replantuhn113x wrote:WD40 isn't a penetrating oil and neither does it purport to be.
Regards, malcolm.
