multimeter
- froggy
- Donor 2023
- My Cars: S2 Xantia Forte 185435.
Peugeot 306 Meridian, the boss. - x 2
multimeter
Hi, Iam about to test the blower motor on my Xantia, with a digital multimeter. I have never used one before. My question is where do I set the middle dial? as there are numbers both left and right of the dail , rising from 200m up to 1000 onthe left and 750 on the right . any help greatfully received, Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Re: multimeter
Assuming it looks a bit like this
You are probably looking for Volts, and on the car this is DC Volts- the V range on the left here. The V range on the right is AC Volts, the symbols beside the letter V tell you this. You choose the lowest range that will include the voltage you expect- for a 12V system that will be 20 in this case.
Richard
Care of a 1994 205 D.
