BRAKE REWIND KIT
BRAKE REWIND KIT
Anyone have one of these - for winding caliper pistons in and out?
Considering buying a kit as over the years I will get use out of it but wondering if worth buying?
Currently have a C5 and my mates about to do his brakes on a Ford Galaxy which also wind in and out.
Jeff
Jeff
Currently driving Citroen c5 2.0 HDI 51 Plate
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
Re: BRAKE REWIND KIT
I only used one probably half a dozen times and just borrowed it from another garage at that time.
Previously I've carefully used a gclamp and a large flat bar (yes I know) but with care and fingers well clear the same results can be obtained, albeit a bit slower.
It is worth buying one, I would of if I had a need to without a doubt but I did not do a lot of brake work anyway...
Andy.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Carefull with C5 front wind in calipers...
One side winds INWARDS clockwise, the other winds in ANTI CLOCKWISE and I cant remember which side goes which way, but you soon know when you turn the wrong way, the piston ALMOST comes out rather quickly.... Dont be caught out like I nearly was..
As for winding in on Citroens, I use a 19mm socket on a ratchet and it works a BREEZE!!! No need to waste money on kits when a bit of home "application" works a treat.
No idea what the VW setup is for winding the pistons back in..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
How does the 19mil socket grip the piston?
The Xantia front Caliper is hollow with a centre protusion spigot... It just so happens a 19mm socket grips it!
Ive got a video of me dooing it somewhere... I thought the C5 was the same, it was a while since I did some. But I certainly remember the caliper piston winding direction!!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
On the C5 the near side screws in Clockwise and off side screws in Anti clockwise.
The piston on the C5 is different but a large castellated socket would probably work. (job for the angle grinder...)
I bought one of these kits on ebay
http://www.ebay.co.uk/itm/180940414241? ... 1497.l2649" onclick="window.open(this.href);return false;
I have found it good and it does say it does a C5 etc i have used it on a passat recently.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Just bought a set from same seller as imperial21 got his.
£15.44 is cheap.
Thanks to all for the helpful advice.
£15.44 is cheap.
- x 54
I'll have to give that tip a go next time. I've always used a file to push and twist the calliper. I need a couple of breaks though as it's fairly knackering!
Kev
'19 C4 Cactus 130 Flair
Pah, Socket small extension and ratchet, wind a fully pushed out Xantia Caliper in around 15min... OR LESS....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Re:
thats what i was thinking, i have a rewind tool and it just takes seconds, fcuk messing about for 15 minutes.addo wrote:Fifteen minutes? Please tell me this is a typo.
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
most of the 15min's is taken up finding the 19mm socket
Regards, malcolm.
