ok installed cruise switch had it switched on with lexia not working. ran diagnostic on lexia came up with 1 of the brake switches active all the time. today went to check switches found white one in place and a red plug with 2 wires no second switch.
what type of switch do i need. is it just a standard brake switch or something else
is it normally open or normally closed
any info at all would be great
c5 brake switch
c5 brake switch
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- waynedance
- x 8
Re: c5 brake switch
No idea but there is many posts on the issue if you try searching. Good luck.
Volvo S80 D5.........
Re: c5 brake switch
Up to RPO 9610 there are two switches on Citroen Service.
The brake switch is part no. 4534 52 . The Contact switch is part no. 4534 37
From RPO 9611 and on up to RPO 10117 there's just one switch quoted which is part no. 4534 40
Hope this helps.
Hope this helps.
Cheers, Kev
Re: c5 brake switch
thanks for that just missed out on the single switch my rpo 9558.
so off to dealers to buy one then
thanks for the help
thanks for the help
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Re: c5 brake switch
bought the switch from dealer got the plastic insert to hold the switch in place from breakers yard. fitted and pluged in went for a test drive and at last i have cruise control. thanks to everyone that helped with this project.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
