Hi All
My front fog lights don't work on my 2001 Xantia HDI estate but can anybody tell me the type of bulb i require before I tackle the task of replacing them?
Cheers
Taff
Xantia HDI front fog lights
Re: Xantia HDI front fog lights
My Haynes gives the fog lamp bulb as H3, 55 watt. A single filament bulb, bit like the H1 in your main/dip headlamp, but (I think) a bit squashed up nose to tail, so as to be more compact
Martin
1995 Xantia TDLX (deceased )
- Xaccers
- x 184
If memory serves Haynes and several websites get it wrong saying H3 bulb and some even say H7
DIY sphere tool
DIY sphere tool
- My Cars: citroen c5 hdi 2.2 auto estate
h3 on the mk1 and h1's on the mk2 like yours, i just did mine so definatly h1, if it helps the easiest way to get at them is thake the indicator out and go down through that hole if youve got little hands, is it both foglights not working if it is check the fuse first in the engine compartment fusebox (cant remeber which one off the top of my head but im sure someone will have a haynes near them)
c5 2.2 auto hdi estate 52 reg
- VertVega
- x 13
They are H1 type and the fuse is engine bay fuse box. I don't remember the fuse number.Taffyrhys wrote:...front fog lights don't work on my 2001 Xantia HDI estate ...
Same fuse controls the headlights washer pump also.
Cheers for the information, i will check the fuse first and then replace the bulbs.
Regards Taff
Regards Taff
