ZX, rough and weak engine.. HELP !!
My 92 ZX 1.4, 170.000km has developed engine problems. The engine runs rough, and esspecially when starting cold and damp it has problems with low power and misfiring. It idles OK but rough when warm.
It stars OK both cold and warm, but the engine tends to stall when the load is removed (cold engine). Sometimes it idles at +2000rpm when cold (I guess this is what it is supposed to do) at other times it settles at the 800rpm. even if it is cold.
I have:
* Changed rotator cap, Leads, Spark plugs
* Checked the vacuum system for suspect hoses etc.
* Changed fuel and air filter
* Had the injector out (no apparent problem) and I ran a bottle of injector cleaning liquid through the system..
No improvement [V] except to the turnover at the local spare dealer[}:)].
I have not had the ECU fault codes read (Haynes computer code book on order, hopefully it will arrive shortly and be a lot better than what seem to be the general opinion of this forum) but I am getting desperate fixing the fault before winter (and the Danish MOT) [B)]!!
If anyone can give me a clue where to look I will be very grateful..[:D]
Thanks in advance
Mads
I have:
Thanks in advance
Mads
Hej Mads -
2 wellknown buggers to check :
1) The engine 2pole temperature sensor - which is ONLY used for the ECU. Quite easy to recognise - as there aint that many 2pole sensors on the engine itself. Usually the sensor's connector plastic piece is either blue or green in colour.
Should be located near the thermostat housing - or at least into the cylinderhead waterways somewhere.
Either the sensor is kaput for good - or the connector/cabling is corroded/dodgy.
This sensor is the "choke" device for the ECU.
It's a NTC resistor - high ohm's on cold - my guess approx 5K ohms at approx 10deg temp.
Get's low ohmic - approx 200-500 ohms at hot engine.
Check it out !
2) The throttle potientiometer.
see this thread :
http://www.andyspares.com/discussionfor ... IC_ID=4093
Check it out !
see this thread :
Got the fault codes out today using the dashboard light and a few yard of cable. See:
http://www.tramontana.co.hu/citroen/fuel/test.html
Very ease and cheap [;)]
No fault codes however [V][?][:)]
Checked the CTS: OK, high resistance at low temp and low at high temp.
The throttle potientiometer seems not so easy to get at, I'll probably remove and clean the throttle housing next [V]. and check the sensors there.. but I don't feel convinced it will cure the problem.
Any bright ideas ???? please !!
Thanks in advance
Mads
Thanks in advance
Mads
While removing the throttle housing - check the ATS sensor the same way as the CTS. It's got the same functional characteristics - which you may also find on Gabor's BX-DIY site (tramontana etc).
Otherwise it may be time looking for any false air problems - while you're there. This may also be caused by any dodgy/rotten vacuum hoses controlling the inlet air.
As your a fellow zx 1.4 owner I have a question for you. Is your engine noisy when the engine is started on a cold morning and then quietens down when its warmed up. Becuase i have been told this is a chracteristic of the engine and just wonder if any other owners of 1.4s have suffered from this knocky noise which occurs when driving the car when its cold.
I have thought maybe its piston slap, but the noise is more noticeable when you pull away and accelerate, but if I rev the engine to 4000 rpm it fades away. The noise has been there since the car was in its youth with 20000 mile on it and hasnt got any worse, it now on 80000 miles. If it is piston slap remind me never to look after an engine like I have with this one ever again i.e. oil changes every 3000 miles or 3 months, with quality oil.
Just changed the oil and put 15w 40 castrol magnatec in it to see if it quietens it down when its cold. When it warm the motor is smooth.
