Zx16v via Lexia3
Zx16v via Lexia3
My ZX16V has intermittent 'Check' Light while driving. This has leads me to check ECU (Bosch MP3.2) via Lexia3.
The fault code that I got are as below:
1)Permanent Fault @ Air Temperature sensor short circuit to positive or open circuit
2)Permanent Fault @ Cylinder reference sensor
3)Intermittent Fault @ Knock Sensor
4)Intermittent Fault @ Mixture adjustment.
On top of that, my ABS warning lights up permanently, from the moment the key is inserted with ignition on. I haven't seen it flesh before.
Lexia3 are unable to establish dialogue with ABS ECU. (My ABS is Bosch, I believe is 2E model)
For Air Temperature Sensor, i tried to exchange with another one but the fault still appear even i've deleted the fault code via Lexia3.
For Knock Sensor, i've also changed and still in the monitoring process
As for Cylinder Reference Sensor & Mixture adjustment, i've no clue what it is all about.
Appreciate if the fellow forumers who can enlighten me on this and advise me on the course of action I should take.
Your opinion & suggestion would be highly appreciated.
Thank you.
Thank you.
Re: Zx16v via Lexia3
Interesting that so many sensors are showing faults.
Educated guesses here, not worked on one of these:
Cylinder reference sensor sounds like another name for a cam phase sensor, should be able to see it if you whip off the valve cover. Probably a magnetic sensor looking at a trigger wheel or something special on the cam pulley itself.
Mixture adjustment fault was probably triggered by the dead air temperature sensor. Although the air/fuel mixture is also adjusted according to coolant temperature and lambda. Clear it off and see if it reappears.
I'd be tempted to have a good blast around with some contact cleaner and checking leads for continuity/resistance before replacing a sensor.
Alex
Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
Thank you, Alex.
I guess i will take care one fault at a time.
I also have consulted my workshop advise.
The first thing that need to resolve is the Air Temperature Sensor.
I've cleared the fault via Lexia3. Thereafter, i purposely disconnected the Air Temperature Sensor and put back Lexia3 for diagnose.
The Air Temperature Reading show '-33 celcius', after 5 mins or so, it change to +19 celcius & stay there. Take note that the Air Temp sensor has been unplugged.
Therefore, I assume there is wiring problem which is the culprit instead on focussing on the sensor itself.
The challenging that i am having is i am not sure the Air Temp Sensor wiring are to be connected to? If it is going to the ECU via a socket, any idea what would be the pin assignments?
If any of the forummers who has the wiring diagram, it would beed indeed great help to my end.
Mine is XU10J4 with Bosch Motronic MP 3.2 ECU.
Thank you.
Thank you.
I should imagine that the ECU defaulted to 19C once it realised that what it was reading from the sensor (or lack thereof) was nonsense. Would make sense as a sort of fail safe.
Haynes manuals tend to be pretty good for wiring diagrams if nobody here has one to hand. The wires should all be colour coded, but they can still be a bit of a 'mare to chase up without a diagram.
previously:
previously:
- My Cars: Past Frenchies , 4xBx16v,1xBxGti,1xBxTzd,2xZx Volcanes,1xZx reflex,1xPug 405mi16, 3x Xantia 1.9td's,1x Xantia activa, 2x Renault 25 V6 turbo, 1 Zx16v ,1 Pug 406 V6 coupe ,1x C8 , 1x Berlingo van , 1x Xanti 2.1td , 1x Renault Laguna 3
- x 35
Have you tried over on the Zx16v Net forum for help ?
http://www.zx16v.net/forum/ucp.php" onclick="window.open(this.href);return false;
Have you any pics too ?
Mark
Mark
Thank you the the feedback.
Yes. I do check it out on zx16.net forum.
on the other hand, i do discover, the air temperature wiring is supplying 12VDC to the sensor. Also, i also do check if the air temp sensor is functioning.
While i switch off the engine, pull the air temp sensor connector out, using my ohm meter to check, i do get the reading approx. 23 Mohm. The engine temperature is around 80 degree celcius at the point of taking the reading.
Also, the connector the i've pulled it off, when i switch the ignition on, using my voltmeter, to check either pin 1 or pin 2 to earth, it does indicate 12volt. Is this normal or it indicate open circuit.
I apologize that I know nuts about electrical. Thus, seeking advise over here.
bx16v, i do have pictures, but not sure how suppose to attach here. Can you lead me on this?
Thank you.
Thank you.
- x 35
Have a read if this samson http://www.frenchcarforum.co.uk/forum/v ... 19&t=35470" onclick="window.open(this.href);return false;
Mark
Mark
Thanks Mark. Going to digest this piece of info & upload the pictures and share it with you....
Meanwhile, I managed to obtain p/n for the following parts:
Air Temp Sensor (P/N: 1920.T0)
Knock Sensor (P/N: 5946.15)
Reference / Cam Sensor (P/N: 1920.L1)
These sensors were hardly available in our country unless at car scrap yard.
One question...
Is the Air Temp Sensor is 12V or 5V? I am getting a little bit confuse over here. Please advise.
One question...
Most sensors work by simply varying their resistance over a range of environmental conditions - with older sensors (pre-CANbus) to put it simply, the car puts 12v in at one end and the other end is earthed through the ECU, which reads the voltage coming out of the sensor. With it disconnected, the ECU initially 'thinks' that the sensor resistance is infinite, giving zero Volts incoming thus the -33 reading. Clearly this is unexpected so (as stated above) after a while it defaults and assumes that the air is at 19 celcius to get the mixture probably somewhere near right. To check the sensor measure the resistance across it at room temperature and then try a hair dryer or something to get it a bit hot and you should see the resistance DECREASE as it warms up. If it does, it suggests sensor is OK, but an open circuit (broken wire) anywhere, or a short circuit in the wire BETWEEN THE SENSOR AND ECU will cause a fault that makes the ECU think it's VERY cold. From what you've said, it's unlikely that you have an open circuit or short prior to the sensor as you have found 12v going in (but try 'wiggling the wiring loom and see if the 12v drops out) and a short would be a (12v to earth) fuse blower.
An air temp sensor fault would very probably cause an intermittent knock sensor fault as the 'assumed' air temperature would be incorrect a lot of the time and could give rise to some knock, so I'd ignore that one until the others are cured.
Cars are funny and although logic suggests they aren't related, sometimes one sensor becoming faulty will often affect others, which might be the case with the cylinder reference fault too, the best rule is often to replace the 'cheapest/easiest first' if they can't be ruled out.
Long post I know, but will hopefully help you understand what's going on. If you post the last 8 digits of your chassis number on here I MIGHT be able to get hold of a wiring diagram for you (if the version of citroen service i have covers your model) the diagrams are schematic and not that easy to relate to the looking under the bonnet, but will at least tell you what colour wire you're looking for and the pin number on the ECU etc
Thank you for your in depth explanation, markflip. I really appreciate your inputs & in fact I do agree with your comments. Concurrently, i do consult some of the citroen mechanic locally available and they also insisted me to resolve Air Temp Fault prior focussing the others.
They also believe some of the faults may potentially caused by air temp fault.
VIN# VF7**************[VIN obfuscated, can be read by forum staff]
I am having an appointment with 1 of the mechanics tomorrow. We are going to troubleshoot / verify the air temperature & the wiring loom. At the same time, need to confirm if the existing wiring that connected to the air temperature sensor is the correct cable.
I believe this is your vehicle? some useful info for you here. I will have a look for the wiring diagram later
Vehicle family ZX
AS RPO No 06736 FV 2 0050
Warranty Start Date 01/01/1990
Engine serial number 10 HJJ5 3003620
Gearbox serial number 20 CM43 6569253
OPB Z017
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY ZX
SILHOUETTE 3 DOOR SALOON
TRIM LEVEL 16V
ENGINE INJECTION XU10J4
TRANSMISSION BVM5 4X2
INTERIOR TRIM TYPE FUJI VELVET "J6"
UPHOLSTERY COLOUR FY
GEARBOX (CHARACTERISTICS) BE3
ENGINE (TYPE) XU/XUD
OTHER BADGE 2,0 I
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE 16V
Vehicle characteristics
TRIM LEVEL 16V
STEERING POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X19
Fuel supply-Engine
IGNITION MAP LIGHTING
FUEL FILLER CAP FUEL CAP WITH LOCK
CYLINDER BLOCK (MATERIAL) CRANKCASE CAST IRON
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) US 83 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
SPEED SENSOR SIGNAL SENSOR HALL EFFECT
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) STANDARD POWER
REGULATION 70/221 (FUEL LEAKS) WITH NON-RETURN VALVE
RHEOSTAT RHEOSTAT
FAN 2 FANS , 2 RATES
FUEL VAPOUR RETRIEVAL NON CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
Gearbox-Driveshafts
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 14 X 62
WHEEL STYLE 15 INCHES WHEEL
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
TYRE (SIZE, TYPE) 195X55X15 V TYRES
DRIVING WHEELS 2 DRIVEN WHEELS
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 24
STEERING COLUMN ADJUSTABLE STEERING COLUMN
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 21
TRACTION CONTROL WITHOUT ANTISLIPPING
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
BRAKING LIMIT FIXED COMPENSATOR
ABS (OPERATION) MOUNTING 4 SENSORS
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS AIR HORN
REAR SPOILER ASSEMBLY WITH REAR SPOILER
SIDE MOULDINGS (TYPE) SPECIFIC SPORT 3
WHEEL EMBELLISHER (STYLE) 15 INCHES ALU HUB CAP
SIDE REPEATER INDICATORS SIDE FLASH-UNIT ASSEMBLY
THIRD BRAKE LAMP W/O EYE LEVEL REAR LIGHTS
ENGINE BAY SOUNDPROOFING BULKHEAD+BONNET SOUND PROOFING
LIGHT CLEAR GLASS
WINDSCREEN WIPER INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
BUMPER SPORT BODY COLOR
NUMBER PLATE WITHOUT LICENCE PLATE
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) MIRROR NON HEATED MANUAL CNTRL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) REARVIEW MIRROR NON HEATED ELECTRIC CONTROL
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES DOOR MIRROR AND HANDLES BODY COLOUR
SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) PIVOTING REAR QTR GLASS
Interior fittings
ANTI-THEFT ALARM ALARM ULTRASONIC+PERIMETER STD
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITHOUT REAR ARMREST
INTERIOR ALARM LIGHTS-ON BUZZER
LUGGAGE COVER (TYPE) LONG SHELF
REAR SEATBELT INERTIA REEL+STATIC LAP
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
GRAB HANDLES FR + RR HANDLES WITH HOOKS
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE LONG CONSOLE
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT
DASHBOARD EQUIPMENT THERMOSHEATHED DASHBOARD
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
LOUDSPEAKER W/O LOUDSPEAKERS
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT SPACER PASSENGER SIDE
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
DRIVER SEAT ADJUSTMENT DRIVERS LUMBAR+LATERAL ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT PASSENG FIXED LATERAL BEARING
INT. UPHOLSTERY ELEMENTS ROOF PANEL HEADLINING F347
ROOF CONSOLE LONG ROOF CONSOLE
FRONT WINDOW LIFT FRT ELECT CONTR FRT WIND LIFTR
REAR WINDOW LIFT WITHOUT REAR GLASS LIFT
DRIVER'S WINDOW LIFT ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER
PASSENGER'S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIV OCCULT+PASS W/O LIGHTING
OIL GAUGE OIL TEMP GAUGE + WARNING LIGHT
HEATING ELEMENT NON HEATED SEAT
IGNITION CODE (OPERATION) STD CODED IGNITION
COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WITHOUT SEPARATION GRILLE
RADIO RECEIVER NO RADIO
REFRIGERATION AIR CONDITIONING
DRIVER'S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
RHEOSTAT RHEOSTAT
AIR CON./TEMPERATURE REGULATION WITH REGULATION AIRCON/TEMP
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG NO DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
CARPET CARPET-RAISED TUFTS F210
SWITCH CODED IGNITION
WATER TEMP INDICATOR WATER TEMP INDIC +RED TELLTALE
LOCKING CONTROL WITH CENTRAL LOCKING
STEERING WHEEL LEATHER STEERINGWHEEL,3 BRANCH
STORAGE SPACE LOCKS GLOVE-BOX WITHOUT LOCKING
Electrical
ALTERNATOR ALTERNATOR 80 AMP
HORNS AIR HORN
BATTERY BATTERY L2 300
STARTER MOTOR STARTER MOTOR CL 3
SPECIAL LIGHTING DIM/DIP
CENTRAL LOCKING CONTROL CENTR LOCK SYSTM DRIVER'SIDE
LIGHT CLEAR GLASS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
TRAFFIC SIDE LEFT HAND DRIVE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
REFRIGERANT REFRIGERANT LIQUID R134
SURFACE CONDITIONS GOOD TERRAIN
Vehicle family ZX
OPB Z017
General information
PRODUCT TYPE CAR
VEHICLE FAMILY ZX
TRIM LEVEL 16V
OTHER BADGE 2,0 I
BADGE 16V
TRIM LEVEL 16V
Fuel supply-Engine
RHEOSTAT RHEOSTAT
Gearbox-Driveshafts
ABS WITH ABS BRAKES
Body fittings
HORNS AIR HORN
LIGHT CLEAR GLASS
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
Electrical
HORNS AIR HORN
LIGHT CLEAR GLASS
Miscellaneous
I believe this is your vehicle? some useful info for you here for future reference, but sadly I don't have the wiring diagram for that age ZX, sorry
Vehicle family ZX
OPB Z017
General information
PRODUCT TYPE CAR
VEHICLE FAMILY ZX
TRIM LEVEL 16V
OTHER BADGE 2,0 I
BADGE 16V
TRIM LEVEL 16V
Fuel supply-Engine
RHEOSTAT RHEOSTAT
Gearbox-Driveshafts
ABS WITH ABS BRAKES
Body fittings
HORNS AIR HORN
LIGHT CLEAR GLASS
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
Electrical
HORNS AIR HORN
LIGHT CLEAR GLASS
Miscellaneous
Vehicle family ZX
OPB Z017
General information
PRODUCT TYPE CAR
VEHICLE FAMILY ZX
TRIM LEVEL 16V
OTHER BADGE 2,0 I
BADGE 16V
TRIM LEVEL 16V
Fuel supply-Engine
RHEOSTAT RHEOSTAT
Gearbox-Driveshafts
ABS WITH ABS BRAKES
Body fittings
HORNS AIR HORN
LIGHT CLEAR GLASS
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
Electrical
HORNS AIR HORN
LIGHT CLEAR GLASS
Miscellaneous
Thank you for your in depth details, Markflip. Really appreciate that.
As for the wiring diagram, i manage to get one finally.
I've done a checking on the air temperature sensor wiring with the pin assingment to the ECU and found the existing wiring the connecting to the air temp is incorrect.
Also, i get the information that air temp sensor only require 5VDC. The exisiting wiring is supplying 12VDC!.
This has blown my air temp sensor though.
I manage to get the correct wiring that is meant for air temp sensor (IAT). It was hiding & left connecting nothing at the engine bay.
Make a connection and replace a good IAT and connect it and it works!
I've also changed the knock sensor (used one) with my mechanic which cost me couples of bucks. And it works too!
The only remaining is the Cylinder Reference Sensor (Cam Sensor, I believe) which is still showning permanent fault and Intermittent Fault for Mixture Adjustment.
However, as of now (after changing IAT and knock sensor with correct wiring) the 'Check Engine Light' does appear in my dash after engine is started. I suppose it is a good sign.
Nonetheless, I think i still need to rectify the Reference Sensor & Mixture adjustment fault.
May i know what is the function of the Reference Sensor & how does it impact / affect the engine performance or operation?
