Xantia 1.8 16v(1996) Lambda Sensor
- dangerousbrian
I have a Bosch Lambda Sensor 258003568 4 wire Zirconia (one plug type) fitted on my vintage Xantia 1.8 16v 1996 LFY engine, which i'm looking to change at 82,000 miles, question is when i look to buy the same bosch one, it has been replaced now with the 2 plug type , does anyone know of say a "fuel parts" or Comparable one , Cheers if anyone can help
1996"N" Xantia Dimension Series MK1, 1.8 16v JP4 LFY
- VertVega
- x 13
Re: Xantia 1.8 16v(1996) Lambda Sensor
You can try ebay.
Another option --> Lambda for Xantia >>"2nd page"
LFY 1996 Xantia says Bosch 0258003717 which is four wires and length 565 mm.
earlier cars had the tip heater and signal wires on seperate two pin plugs later cars were on a single plug usualy black with red tangs marked 'SAAB' for reasons i dont fully understand, Also bear in mind you pay for the plug, if you find one cheaper you can always solder your old sensors plug onto it if the price difference is huge, i think Citroen want £200 for thee old two plug setup.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- dangerousbrian
http://www.onlineautomotive.co.uk/Produ ... ryID=55153" onclick="window.open(this.href);return false;
i have found a Fuel parts number LB1015 is a one plug type,so will order, i did want that bosh one 0258003717 , i tryed my local spares shop, and ordered the bosh one, but it had 2 plugs on it and was told that the part number had been discontinued and now only 2 plug type was used. Thanks
