Hey, so here is the HP pump on the Xantia (picture shown at bottom of post).
There is a leak from between the bottom nut and the pump.
I've got the O-ring.
I know to watch out for a spring and ball bearing when removing the bottom nut.
I was just wondering about the LHM fluid.
I presume I lower the car down to it's lowest setting to depressurise the LHM as much as possible.
Do I need to empty some of the LHM out before removing the pipe, if so where from?
Or can I just remove that bottom nut, (placing a bowl under the car and a rag over the nut), and just swap the O-rings over?
Cheers, Romie
Xantia HP pump leak, seal replacement
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
Re: Xantia HP pump leak, seal replacement
Yamaha R1 1999 26k
Yamaha R1 1999 26k
Ah, that's better
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- x 54
That one you have circled is one of the high pressure outputs. Its good practice to lower the suspension and turn the 12mm pressure regulator screw on the accumulator sphere block by half a turn just in case.
Once you've loosened the nut on the pipe you'll need to pull the pipe out a bit as it can get lodged in there proper after a while!
Kev
'19 C4 Cactus 130 Flair
- VertVega
- x 13
I think it is the high pressure line which goes to the regulator.
Protect your alternator with a plastic bag and cover also A/C compressor below even though it is a tight package
- Dommo
- My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306 - x 19
It looks as though your auxillary belt has jumped across a tooth and shed a tooth of belt, get that changed ASAP!
Worth checking if your tensioners are wonky too as this can cause the belt to move a tooth, I had this issue on my 1.9 306, a broken AUX belt on a Xantia is NOT a good thing, you will lose brakes after a couple of pedal presses!
cheers for thoughts.
That belt has been like that since I got the car a year or so ago.
Yup, I def need to change aux and timing belt sooner rather than later :/ sigh.
Great, I'll do the above, ta
Yamaha R1 1999 26k
Yamaha R1 1999 26k
i find if you clamp the main suction feed rubber pipe going to the pump you loose less citro blood (LHM),
also try not to disturb the spring and plundger under that pipe union,
regards malcolm
regards malcolm
