ax battery drain on ax
i have a 93 ax found there is a drain on the battery with the ignition off..if remove the relay its ok ..iv swoped relay so i know its not that and disconected rear screen and theres still a draw from the battery with ignition off any one got a wiring diagram or any general ideas
have you fitted any thing to it eg.different stereo/amplifier,carphone ? connect an ameter in series with the battery & check the reading,start removing fuses one at a time,if when you pull one out and the reading drops then this is the circut with the problem.which relay are you removing that makes it ok ?
its the rear screen relay that when removed stops the drain.. when fitted and ignition on and useing the rear heated glass switch it seems to function as it should when the relay removed it only seems to knock out rear glass heater all other electical systems work fine..there are no alrams radio amps or extras at all fitted to the car..
