For the last few months, I have had a dull thump from the front wheels and steering vibration. Today I changed the droplinks and the dull thump has gone however, the steering vibration remains. Its not wheel balance or tracking as have had these checked. When driving today, I adjusted the steering rake and low and behold no vibration - at least for a short time and then it returned. I read somewhere that there was a known fault with a clamp on the steering rack that needed to be pinched tighter. Can anyone point me n the right direction or provide any advice.
p.s. it passed MOT last week and is a Mk1 110 diesel estate
Also might be worth saying that my rear has been dropping for the last eighteen months when parked. I raised the rear on trolley jacks and lubed everything I could and did some citrobics. Appears to have done the trick. so far anyway
C5 Steering Vibration
- My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10 - x 110
If it is the camlp on the steering rack then you will get a rattling/chatter through the steering wheel over rought surfaces. Are you getting this?
If the wheel wobble is at speedo and not making a noise in the above way, have a check that your front brakes are not binding on. The handbrake levers on the front calipers have a tendancy to get a bit sticky and hold the brake. This does very often cause a wheel wobble.
19 Hyundai i10
19 Hyundai i10
Cirtroenmad many thanks. Yes its only on rough surfaces and can best be described as a chattering. Have checked brakes are not binding and handsbrake ok.Citroenmad wrote:If it is the camlp on the steering rack then you will get a rattling/chatter through the steering wheel over rought surfaces. Are you getting this?
Yep, that does sound like a problem with the steering rack clamp having play in it.
I believe it can be removed and pinched and that does cure it. I have not done it myself though.
19 Hyundai i10
19 Hyundai i10
You will find it is where the column passes through a bush down low near the universal joint. It was a common issue on the early C5's, and a revised column was released. I had it on my 2002, never fixed it due to cost. Now driving around in one of the last Mk1's and happily this is not an issue.StevieOMG wrote:Cirtroenmad many thanks. Yes its only on rough surfaces and can best be described as a chattering. Have checked brakes are not binding and handsbrake ok.Citroenmad wrote:If it is the camlp on the steering rack then you will get a rattling/chatter through the steering wheel over rought surfaces. Are you getting this?
That is interesting, I didn't know it was modified along the production run. I have only had that problem on a 2002 C5 and not later ones, which explains it.mlkey wrote:You will find it is where the column passes through a bush down low near the universal joint. It was a common issue on the early C5's, and a revised column was released. I had it on my 2002, never fixed it due to cost. Now driving around in one of the last Mk1's and happily this is not an issue.StevieOMG wrote:Cirtroenmad many thanks. Yes its only on rough surfaces and can best be described as a chattering. Have checked brakes are not binding and handsbrake ok.Citroenmad wrote:If it is the camlp on the steering rack then you will get a rattling/chatter through the steering wheel over rought surfaces. Are you getting this?
19 Hyundai i10
19 Hyundai i10
