Hi, to gain access to the electrical connectors to the hydraulic pump (well the 2 smaller ones anyway) do you have to remove the lds reservoir because I'm beggared if I can get my hand in as there is a pipe in the way or am I missing a trick.
Cheers
Hydraulic Pump. C5
- x 9
Looked pretty imposible to me too but as the pump was coming out I didn't try too hard, even with the LDS tank out of the way it is still tight. You can unbolt the tank, two bolts into the wing and move it a little without having to remove pipes. It's not a hard job to remove the tank just lots of other things have to come of to do it, like all the wheel arch liners, after that it's only a question of draining the oil into a clean (very clean !) container if you plan on re-using it.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
