I am troubleshooting some central locking issues, can someone please tell me where I find the sensor which detects whether the driver's door is open/closed? Year 2000 xantia hatch.
Cheers,
Ainslie
Door closed/open sensor on S2 Xantia?
- Gingerposer
- x 6
- Gingerposer
- x 6
When I try to lock the car using remote, all doors except drivers lock, then it reopens them and beeps once. Button on drivers door doesn't move when doing this. Car locks on from drivers door using key. I now have the trim off the door to examine the insides. As far as I can tell, the mechanism which should lock the door only does so when turned with te key. It doesn't even twitch when the remote is tried.
- Gingerposer
- x 6
- Gingerposer
- x 6
- My Cars: Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD - x 8
Hi
The sensor resides inside the door lock block. I had the same problem , I aligned the door lock and the lock striker and this fixed the problem. The alignments is done by releasing the two screws that attaché the lock striker to the cars body and relocates it till it is in the center of the door lock.
Zohar
Zohar
- Gingerposer
- x 6
No need to remove the door trim, before releasing the screws mark its position with a pencil. You can slightly move it in, out, up and down. As I understand it the lock striker sets the position of this U shape part of the door lock. This U shape part in conjunction with the door lock mechanism determines if the sensor is on or off. You can use a flashlight and live the door crack open and see if they aligned.
Zohar
Zohar
