synergie failed the mot.
hi all. well it was mot time for my car today and suprise suprise it failed lol. anybody changed a fractured front coil spring? just wondering how easy it was to do on the synergie. i have the spring compressors so im hoping to do the job myself.
i have just replaced a pair of front springs on my freinds Picassssooooo,
firstly every thing was rustted solid, i had to run a grinder throught the pinch clamp bolt at the bottom of the shocker,
then once the shocker was seperated from the hub carrier i had to heat both sides of the pinch clamp to get the two halves of the bolt out,
also the un/sprung length of the spring requires very long spring compresors, as it needs to be compresed an aufull long way to get the spring cap/strut top back on,
at least on a Picassssoooo anyhow,
regards malcolm
regards malcolm
as long you give all the nuts and bolts a good soak with WD40 first it shouldnt be too hard a task just ensure the springs are clamped securely before you remove the bottom retaining nut i personally loosen all bolts etc first as the presure from the springs tends to help stop things spinning if theyre rusted on.
Yipee i have the xant lets i hope i keep her this time
Excellent.dave2011 wrote:all passed
Has this problem that affected many makes and models generally been resolved now?
Bad batch of coil springs seemd to be a major problem a few years ago, had one snap on my Partner van 8 years ago, but don't hear about it so much now fortunately.
Colin
My cars:
1988 AX GT and still running sweet. Genuine 41 k only!!
2005 Skoda Fabia vRS 83k...and truly awesome.
Vauxhall Combo crew cab SE
Citroen Saxo 1.4 Furio.
Their cars:
Hyundai Getz.
Hyundai i20
Eriba Puck caravan now too!!
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
didnt know there was a bad batch of springs but saying that i changed the front drivers spring on our lasses mams 306 n that dont do much miles so maybe there was dodgie springs fitted to the cars yrs ago? mine had fractured at the bottom where it butts up to the strut n did,nt find out till it went for the mot......... weird really as the car drove fine.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
