Windscreen wipers are fine on all settings except normal wiper mode, ie, fine on intermittent or double speed,just don't work properly when you want constant/normal wiper operation..typical
Not a big issue for me,(well, it's a bit of a p.i.t.a) but the wife can't suss it. So I'll have to sort it.
If you push the wiper stalk left,towards the steering wheel,it seems to work ok.
Now then, could I take it off and clean the contacts etc, or is it buggered?
Central locking:
Sometimes the locking's being a pain. If I press the fob, (which would normally go 'blip',lock,flash indicators),locked.
it goes blip..bloop,locks and unlocks again.
Haha,sorry, it's the only way I can describe it
It's not a seatbelt stuck in the door sound,it's different.
I then have to mess with the key,till it locks.
I have noticed the drivers door card has come away a bit,coincidence?
Any ideas welcome : )
2 quickies chaps - wipers + central locking
1999 Xantia LX 2.0 HDI 110 Rusteration project...
- DickieG
- Monaco's youngest playboy
- x 38
If the doors are correctly shut and the central locking immediately unlocks then check the contacts where the loom block connects onto the door locks. I've had this problem a few times now and each time the culprit has been the N/S/F one for some reason. If you're near anyone with a Lexia, that can be used to tell which door lock is causing the problem.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Yes the doors/boot are all correctly shut with no obstructions.
Cheers, Dave.
Where will I find the loom block...in the door, or in the footwell etc? I'm struggling to find it in the Haynes manual.DickieG wrote: check the contacts where the loom block connects onto the door locks.
Cheers, Dave.
- DickieG
- x 38
In the door itself, where the block connector plugs into the door lock assembly remove the doorcard to gain access.HDI Dave wrote:Where will I find the loom blockDickieG wrote: check the contacts where the loom block connects onto the door locks.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
