Problem with the Lexia
- My Cars: Xantia 2.0l 16v 2001 petrol
C5 mkII 2.0l petrol sx pack 2007
C5 x7 saloon petrol 2010 - x 6
Hi
I've recently bought the Lexia clone. it came with the software cd but I cant install the program on my pc. it starts to install and then it stops. I've downloaded another software but with the same results. any ideas?
Thnx.
Thnx.
- VertVega
- x 13
Is it a 'clean' PC where you're trying to install? I mean was there any version of lexia installed/uninstalled previously?
The CD installation version should be (or usually is) LEXIA-345.13
- VertVega
- x 13
That's becoming a bit confusing
You have Administrator rights (?) while trying to install it.
Does it create new folder as C:\APPLIC
Try to get another installation package and try with it?
May be the setup media has some damaged files in it
Hi
Thanx for your good will and efforts. I was wrong. I've creates a file, not a folder (version.txt) under c:.
VV- no, it doesn't create a new folder.
acrowot - I'm not getting an error message or any other message. it is like if it was in the middle of the process, but there is no process.
Mike T - I've downloaded the ver45 since I was thinking too that the media I received with the instrument was faulty. when I expand it, I'm getting a lexia3.nrg that contains a setup.exe file. after it expandes, an instashield wizard window with french writing appears, seems like it starts to install and then...nothing.
still in hope...
still in hope...
Mine is the same version as yours, to install I have to open the Lexia 45 folder and click on a file in there called instlex.exe, a window then opens and at the bottom left it says "Valider pour continuer" on the right hand side of this window half way down is a red box with a sort of star and like an enter symbol this is the validate key, when I press this the next window appears with the countrys flags in it to select the language. Is this what happens with yours so far, it does take a long time to install.
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 232
An .nrg file is a (nero) disc image I think. "Expanding it" sounds like a hack and if said hack is then automatically running setup.exe, then that's where the problem lies, I'm sure.atr wrote: when I expand it, I'm getting a lexia3.nrg that contains a setup.exe file. after it expandes, an instashield wizard window with french writing appears, seems like it starts to install and then...nothing.
still in hope...
If you burn the CD image, there should be an installation doc/help file that explains which file on the CD you use to install Lexia software. Could well be instlex.exe as acrowot pointed out but it's definately not setup.exe
