The BX estate is wonderful but a little small sometimes[:)]
I had to shift some 3 metre ling stuff recently. The front seat came out most obligingly but I had to remove the rear cushion as well. It is only a pair of nuts to spin off. I will replace them with wing nuts to make it easier next time. The torx driver is standard equipment in the golve box. NB how do you double the size of a BX glovebox? You clean it out with a cotton bud[:o)]
Getting more in
If it makes racket then strap it down a bit better!! 5canoes and 4 compression straps and there aint a noise (once you drive 2miles get out and duct tape the aerial to the roof!).
But seriously, i keep looking at the minute sixe of the glove box and have to wonder about all the space above the glove box. Am i right in thinking that some european BX had an upper glove box?? Still its big enough to get everything i need in it.
- Contact:
Huh you think the BX glove box is small, try a Xantia, the only gloves that fit in there would be for a one armed midgit:-))
Pete
________
NEVADA MEDICAL MARIJUANA
Pete
________
