hey all, noticed my c5 is wandering a fair bit lately so ahve changed the drop links and track rods, really could do with balljoints i recon as still a bit floaty
is it a diy job or a garage job??
cheers
c5 balljoints
- x 9
Re: c5 balljoints
If you have the tools and knowledge anything is DIY . Myself couldn't be arsed to buy the special tool required to unscrew them so gave it to my local Indy 600 Miles later front wheel comes adrift luckily at low speed, ball joint had become unscrewedsportingfiat wrote:hey all, noticed my c5 is wandering a fair bit lately so ahve changed the drop links and track rods, really could do with balljoints i recon as still a bit floaty
cheers
From this I learn't the following, the Citroen part apparently comes with the threads pre-coated in thread locking compound also with a new heat shield, the independent after market one that I supplied didn't. Now i had no problem with the garage putting all the damage right they accepted that on at least two counts the item had not been fitted correctly i.e no thread lock had been applied and probably most damning the locking ears had not been peined over, whether it had been torqued up to the correct value we will never know but personally I doubt it. I do know that had I done it it would have been done correctly.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Hi
I will be interested to know how easy it is DIY, My C5 is beginning to handle like a drunk bouncy castle. Is yours knocking a bit too?
Cheers
Andy
Cheers
Andy
1999 Citroen Xantia 2.0 HDi 110 Estate
2001 Citroen Xantia 2.0 HDi 110 LX
1999 Citroen Xsara Picasso 2.0 HDi 90
1983 T25 VW camper
1994 Mini 1275 35th Anniversary Edition - sold
2007 C8 2.0 HDi 136 Exclusive - sold
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
I changed drop links and the loud knocking went away. But i think i can hear another one, much fainter, cant quite tell where its coming from at the moment
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
I did mine 2weeks ago drivers side bottom ball joint and i also purchased the proper castle socket. I found the socket useless to undo the ball joint it slips out of the cutouts easy when pressure is aplied, 1 hour later i decided to remove the disc and caliper and used a a stilson pipe wrench and this took all of 2mins. I then used the castle socket to tighten the new ball joint, make sure you hammer over the 2 locking tangs in the slots once the new ball joint is tightened. If i do the other side i will use the stilsons at the start to save swearing and wasting time.sportingfiat wrote:thanks for that , looks like im gonna order the tool as its only £8
the balljoints are non Citroën but luckily i carry a van ull of lockitite
will let you know if its a pig to do
cheers
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
WWP, did you have the balljoint's nut screwed down snug to retain the castellated socket? Surprised if you did, and it still slipped.
Just a reminder for anyone doing wheelbearings in addition to balljoints: Late 405 through 406, Xantia through facelift C5 all have the same basic hub carrier. It may be faster if you purchase a pair of usable hub carriers, fit the new balljoints then changeover the hubs with new bearings.
