I'm done with sorting out the other brake problems and now have hydroflush in my 1994 Xantia. Next week I'll put new LHM in.
I still have a problem on thr right front wheel. When I bled the brakes I noticed that this wheel had much less pressure than the other 3. I also took out the pads to sand them down a little because this wheel makes a grinding sound when braking (disks are fine). I noticed that one of the pads is more worn and glased (fealt very smooth) than the other.
The grinding noise dissapeared for a while but is now back. I suspect that the pad is glased again and it could be due to the lack of pressure to this wheel. Any suggestions as to what could be causing the problem?
Brake problem
what I meant to say is that the handbrake cable may be a cause of the uneven wear I've experienced this on a bx.
If there is a significant difference in pressure to the front brakes then this must be noticable when driving, the car pulling to the higher pressure side when braking (hard)or maybe the abs working to compensate ?
If you could get the car to an mot station they could measure the braking force at each wheel.
another possibility is that the bleed nipple simply isn't allowing the same level of flow.
mark_sp
mark_sp
