Wiper problem
Wiper problem
Hi I own a Citroen ZX 1.9 diesel and when I turn on the wipers the fuse for the indicators blows. Any idea how to fix this?
wiper problem
I'll give it a go Thanks
Another option might be that the motor is stuffed. Easy test is to disconnect it from the loom in the scuttle and run a couple of wire jumpers to the connection block from the battery. You will need the wiring diagram for the pining sequence, so you know what is the constant lives and the earth/neutral.
Handyman
Handyman
