Hi!
My 1997 1.8i Xantia is running cold. As it was -22 degrees when I got up this morning, that's a very bad thing!
Anyway, I think it's time to change the thermostat. As the tiltle suggests, anyone ahve a picture of where the thermostat is located on the engine, or any advice about changing it?
Thanks ever so much!
Charley
Anyone got pictures and/or experience of Xantia Thermostat?
The thermostat sits inside a removable plastic domed housing on the main
feed pipe running onto the cylinderhead at the gearbox end. You'll see it easily
enough as it's between the rad and the engine and there will be a car tyre
valve cap screwed onto a bleed outlet on it's crown. This thermostat housing
is held with just x2 10mm bolts whick comfortably pulls off the O-ring seal
showing the thermostat inside the feed.
Make a note of the orientation of the existing thermostat as there is a direction
to them and your current fitment may even be incorrectly fitted or the wrong
type!
Andrew
type!
Andrew
- VertVega
- x 13
I have pic of from a MK2 Xantia.
andmcit, are they similar?
Edit: Now, I know that they look similar, different design
Firstly, thanks for the help!
Temperature comes up nicely to about 80 degrees now, so nice and toasty on those freezing mornings.
The new thermostat cost me 150 Kronor, which is about 14 quid, so not too expensive either.
Thanks again for the help everyone.
Charley
Actually, it's 2 bolts and one nut, which I didn't see till I'd prised the housing loose and snapped off the bottom corner of the flange (where the nut sits). Whoops!! I put a larger washer under the nut so it holds the flange in place and it does't seem to leak!andmcit wrote: just x2 10mm bolts whick comfortably pulls off the O-ring seal
Charley
Hi Charley,Nekkid wrote:Actually, it's 2 bolts and one nut, which I didn't see till I'd prised the housing loose and snapped off the bottom corner of the flange (where the nut sits). Whoops!! I put a larger washer under the nut so it holds the flange in place and it does't seem to leak!
whoops indeed. Apologies if I misled you with the number of bolts fastening it!
I've only seen these with x2 bolts and do believe the housing is one too few
to triangulate the fastening and it's foces which appears to have been rectified
on the later cars. Least it appears to be holding but it needs to be watched
as the sudden failure may lose coolant with bad consequences to the engine.
These thermostat housings aren't hideously expensive - the one pictured is
showing up as:
00001336J4 WATER OUTLET 10.69 GBP 12.56 GBP 12.56 GBP
modest money for what it does!!
Andrew
