ZX Turbo's
ZX Turbo's
From new, the ZX TD came equiped with either the Garrett Turbo or the KKK Turbo. Now apart from the wastegate been adjustable on the Garrett but not on the KKK, what are the pro's and con's to owning each[?]
- Contact:
With the Garrett there is a VERY clear wastegate arm on the outside of the turbo. On the KKK this is contained. hence its easy to assess which is which. BUT the KKK is supposedly the easier of the two to adjust!!
have a read of this;
http://homepage.ntlworld.com/ken.waters ... ng/306.htm
The kkk turbocharger has a straight hose connection from the side, and an elbow connection which needs to go on the top, making both hoses point to the right hand side of the car. These are secured using jubilee clips.
The Garrett turbocharger has a straight host connection from the side, but the top hose is a moulded one-piece to the intercooler, compltete with rubber seals, which sits inside a casting in the top of the turbo, and is secured using bolts.
As mentioned before, the Garrett has a more obvious wastegate.
Thanks for messages so far but what i am really after i suppose is - which one is best?
I am in the middle of rebuilding my ZXTD engine and have both turbo's available to me to drop on.
It may be down to personal choice or preference, or someone may know that out of the two - one of them is a bag of nails!
If one is better than the other - then i would want to be fitting that one[:)]
Andy.
Andy.
Just to add to that, I was working at a Citroen delaer in 1994, and a few people with ZX TD's purchased new came in and complained that their car whistled excessively. Some turbo's were changed under warranty, always Garrett ones. But any Garrett equipped ZX TD always went like a train, I'm certainly prepared to put up with the whistling.
