Hi All
Not been on for a while - the Xantia is behaving itself - MOT due in Jan so may it continue. I am thinking about changing the coolant as winter is now upon us - flushing out the rad and topping up with fresh antifreeze.
I've not done the job before and Haynes makes the job sound ok with just two spanners in terms of difficulty rating (last time the garage did it - second cam belt change so had water pump done at the same time).
Any tips from anyone? Which antifreeze to use (I have seen reference to Antigel and also a Mercedes product) - does it matter which? Also do I need to open all the screws or just the one at the bottom of the radiator.
Look forward to the replies.
Nige
Changing the coolant in my Xantia Estate
NEW 50 Shades of Grey C5 Tourer 2016 BlueHDi 2L VTR+
C4 (62) 1.6HDi VTR+ (Feb 2020)
Silver Dream Machine: C4 Hatchback, 1.6 SX HDi (07) (July 2013 - Feb 2020)
C5 Tourer Exclusive 09/2Ltr HDi (Oct 2012-Sept 2021 146K miles
Xantia Estate Mk2 1.8LX V-Reg/2000 173K miles.
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
No its quite straightforward.
Tip (apart from a cold engine!) , leave the radiator cap ON and undo the radiator drain tap (if it has one) , then undo the rad cap. The reason is simply to avoid a shower
You may want to hose it out. I'm not 100% sure where all the bleed screws are on a petrol.
There will be one on the heater hose by the bulkhead (a plastic tyre valve type cap)
One on the thermostat housing (probably a 5 or 6mm hex head brass bolt, caution: do not use excess force)
One on the radiator itself (opposite end (still the top obviously) of the cap)
You will need to carefully bleed it when refilling and running. Failure to bleed the air out is very bad.
Tip: Get a 2litre plastic orange / coke bottle and cut the bottom off. Jam that into the rad cap orifice with a rag if needed. Fill it with that. Keep about a litre of coolant / water in the 'bottle'
I assume the manual states the procedure ? , basically undo the bleeds fill it and shut them when coolant emerges without bubbles. If you have a brass one on the thermostat housing, I would advise removing it completely temporarily to help. Do not lose its little washer if it has one.
It is a lot easier to do / show someone than it is to explain though.
Andy.
My recommendation would be to use a silicate free coolant, my preference is Honda genuine type 2 ready mixed coolant.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- VertVega
- x 13
Very good and detailed explanation spider
I've sent pics of bleed points in this thread ---> Xantia 1.8 petrol, cooling system bleed points <---
Thanks Chaps - great pics and detail. Don't know how I missed the threads - I did a search. Anyway - I'll have a bash at the weekend.
Nige
Nige
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Just as an added piece, Flush the Heater Matrix....
You can carefully remove the hoses with an aid behind the plastic elbow, if you hold the clip in the undone and gently lever the elbow from behind with a large screw driver, DO BE CAREFULL, but its safer then tugging from the front....
You can the flush out the matrix OR OR, thinking about it, remove the hose from the back of the head, probably safer, and blast a hose in that way... should help to clear the matrix out too...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Ive successfully removed them with the method above... takes a bit of judge ment... though... thats only why I mentioned it.
But thinking about it, yes, take the hose off the back of the head, gearbox end.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
