My car is a xantia 1996 SX TD, when I switch on the A/C I find it very difficult to see the light on the switch during the day, it is OK at night time,is this normal?. Every other Xantia I have tried has the same very dim light on the A/C switch.
John
Xantia A/C Light on switch
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
I do have a 'workaround'. You drive for a few minutes, with temperature setting to minimum. If you do not feel a cool breeze, press the air con. Drive for a few more minutes. Either you feel a cool breeze and then know the air con is on or you don't and know the air con needs a service.
Actually we should be glad that the Xantia AirCon is quite good - many lesser models have quite a weedy air con. Mine began to be less effective last year but a well spent £80 service sorted this out and it's back to full icy output - even if the light isn't!
The heat from the bulb blackens the green plastic bulb holder inside the switch so reducing the light output.
I swapped the bulb holder in my aircon switch for the one in the rear window isolator switch or the volumetric sensor cutout switch, I can't remember which. Problem solved at least for a couple of years.
I have bought replacement wire-tailed 12volt bulbs for the illuminated switches from Maplins in the past.
Richard
Richard
