Just wondering if anyone knows how to remove the o/s rear door protector, as I can see a bit of rust below it which i'm going to sort out, but can't get to it unless the protector comes off.
Do they just clip on, or will I have to take the inside of the door apart to get it off.
Xantia rear door protector removal
If you are referring to the wide strip approx half way down the door then on my S2 Xantia the strip is retained by clips located in holes within the door skin... easy job, all accessible without requiring removel of inner door panel.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Well I don't know the official way but mine got caught on something and popped off easy enough, I suspect that if you use something broad and plastic (ice scraper perhaps) and gently lever at one end you will get it to pop off though you will probably snap the clips. New ones are readily available and cost pennies... insert the new clips into the strip and offer it up to the holes in the door... about nine holes if memory serves correctly.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Forgot to mention that my old XM had double sided strip tape holding mine on.. not sure about the S1 Xantia!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
