Hey guys! Im looking for the plastic slider that is on the window regulator from a 2000 Xantia 2.0 Hdi Mk2 .
I believe you can only buy the whole unit from Citroen but is anyone breaking a car? Or knows where I can get a new plastic slider? Cheers
[/img]
Xantia electric window regulator part needed
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
I might have one as I have a couple of regulator assemblies knocking about, will check later.
Lexia ponce
Lexia ponce
Well I found the part you show in the pic but it's the opposite hand but I also have a complete regulator minus the motor of the correct orientation which you are welcome to.
Lexia ponce
Lexia ponce
Yes, it's simple enough to remove, if you want to PM me the address in Spain I'll send it direct if you like...
Lexia ponce
Lexia ponce
