Via the injection ECU I dont think that it looks at throttle position as such rather a demanded torque figure which I think is derived from throttle position and engine revs.xantia_v6 wrote:Well I still think it sounds like a sensor fault. I don't think it is likely that an ECU fault is giving the symptoms you are describing.
Does the transmission ECU get its engine load signal direct from the throttle, or via the injection ECU? I suspect that the latter is more likely.
I did take on board your previous comments as regards sensors and seriously revisited the issue,
As far as I can see the ECU only gets three bits of data from the box. input revs, output revs and oil temp and all three sensors are buried in the box, the rest of the data consists of selector and brake inputs (hardware) the rest of the data including dynamic data e.g pitch attitude comes down the CAN bus from the injection ECU and ESP/ASR ECU,
According to the Lexia the outputs from the box are fine and having done several recordings of them they all look sensible to my eye,
But just because the Lexia is being told that that they are good by the ECU and displays data that the ECU gives it doesn't mean to say that there isn't something there which gets filtered out by the ECU,
Given that even when driving the box Tiptronically the ECU still keeps a watchfull eye on the gears selected and will and does overide and change gear if the conditions are potentially damaging, I would imagine that if there were a problem with any of the sensors then this would not work either, in fact thinking about the protection aspect I wonder if there was a problem whether the box would change gear at all probably not except maybe to go to third gear emergency mode.
What I really need is a REAL expert that has the gear to really see what is happening in the ECU, and the breakouts necessary to really examine the signals between the ECU and box.
Having said all of that it has been warm these last few weeks and the other day when in that area I was suprised at just how hot the ECU was after a run, we are talking seriously hot like you didn't want it in your hands for too long. The ECu sits on top of the injection ECU and there is a plastic cover over all that with as far as I can see little possibility of any natural airflow to aid cooling I can't imagine that running at elevated temperatures is good for either the auto box ECU or the injection ECU.
I don't know yet if it is coincidence or not but the last two days the air temp has been considerably cooler and the box has for the most part worked as I would expect it to, so for a while it is a monitor it situation and try to find an autobox specialist that I can have some confidence in.
But any other thoughts or offers of the breakout cables that would allow me to scope the signals from the box to the ECU welcome
cachaciero
