Berlingo 1.4 Transmission Oil Level
I'd really appreciate a quick bit of help. I'm trying to service my 1.4 Berlingo and want to check the transmission oil level, but cannot find the plug anywhere.
Looking through the Haynes manual I have something similar to the MA5 transmission. The drain plug is situated as per the photo in the manual, but the level plug isn't in the end of the gearbox casing (just under the left hand bolt for the end cover).
For the life of me I can't find another square section plug anywhere on the casing. Any ideas from some one with a little more experience?
Thanks, Jon.
Thanks, Jon.
welcome Jon
i cant think off hand but on a XANT looking at the end of the gear box fom under the N/S wheel arch/chassis rail, on the end that is faceing you there should be a large tin end cover, they dont always have a square/hex hole for a plug tool to fit into the level bung,
and just to the bottom left edge there is a larger bolt than the one's holding the tin end cover on, that should be the level bung, i always use the plastic vent on top for filling, i think on the SAXO you just pull the top off,
regards malcolm
regards malcolm
Malcolm,
Thanks for the quick reply. I've got the tin cover, which has three retaining bolts, but there is no additional plug for the level.
The aluminium gearbox casing follows the profile of the cover exactly, whereas in the picture it has a 'teardrop' profile that extends below the left hand bolt with the plug in.
I had thought it might be a sealed for life unit, but why have a drain plug still?
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
It's more or less in the same place on these, but its on the other end (as in nearer the front of the car, the bigger BE gearbox has it at the back nearer the bulkhead)
There is a plug on the side (a larger headed bolt on the tin end cover) that is the combined filler / level plug.
You've already seen the drain plug underneath anyway.
Here is a picture (not mine I just found it) of a 106 which is the same gearbox really...
Andy.
- spider
- x 77
- Contact:
I think we are going to need to see pictures of it ideally then.
You might have a splash shield between wing and gearbox but it should be possible to get a shot from underneath and possibly in the gap without taking the shield off.
It will be (probably) a round plug with a square recess or (less likely) a larger bolt, as in about 17 to 19 mm compared to the 10 to 13 mm ones.
Pics would help us point you where though first. Don't go undoing anything just yet
Andy.
Andy,
Thanks for sticking with me, hopefully these work;
Shot from under the wheel arch showing the tin cover, but no filler
Shot from under the bonnet. I've just found this black pipe, which looks like a filler. There's no dipstick under the cap so I've no idea how you'd check the level, but it looks like you could fill the gearbox through it.
Perhaps I'd have to drain it all out, then fill with a measured amount?
Thanks,
(Sorry they're a bit big -I'll try and resize them)
Thanks,
- x 3
that bleck pipe is just the gear box vent/breather, and as the flying clutchman say it shouldheve a push fit cap over it, this is were i fill via but i never feel the need to remove the reversing light switch as i never get blow back,
try removeing the bolt at the front lower end cornner of your tin end cover, it might be a level bung as well as a tin cover retaining bolt,
regards malcolm
regards malcolm
Thanks Everyone,
I appreciate the time you've taken to reply.
I got the oil changed today by draining it all out, then putting 2 litres back in through the filler.
Still can't find a level though - I had already taken out the end cover bolts one by one, but the threaded holes are blind and don't seem to go through the casing to allow them to act as a level.
Anyway all done for 40k or so!
