I agree totaly, on an Astra i had (my first 4stroke porting project) everything was polished to within an inch of its life, the piston crowns, inlet and exhaust ports, after running the engine and taking the head back off you could plainly see where the fuel had formed droplets on the intake and on the now polished piston crowns, this polishing made a slight difference for the worse, i quickly found i lost power! the gain came from enlarging the throats of the inlet/exhaust ports to match the manifolds and gaskets, also cutting back the casting around the valve guides and blending in the seats made a noticable difference from above 2.5k rpm with wide open throttle, mind you just replacing the valve guides/piston rings will give a power increase in an old engine and i think this is where my efforts will go with the tct engine, that and Xantiamans patented tomcat turbo thefthandyman wrote:The trick to port 'polishing' is blending, ie, get rid of any obstructions in the inlet or exhaust so the flow is unimpeded on its way to and from the combustion chamber.
The ideal is smooth, with the surface down to a good 'flat' finish as left by a 200G flapwheel. It has been shown that a mirror polished surface can cause the atomised fuel to form droplets on the surface of the inlet port, which is wasted effort.
Increasing the size of the port, without understanding the conditions the engine will be working under can have a deterimental effect. Better effort is spent making sure all the components on the inlet or exhaust match, with no obstructions. Mismatched manifolds, gaskets that do not fit, bad castings are all worth checking and easy to rectify and give an easy power gain.
H
Steve
Strange how Citroen put so much effort into the 2.1 intakes yet none at all on the tct, both being turbo's i guess that blows my theory out of he water, or maybe they had something to prove with the 2.1 and wanted it to be as good as they could practicaly make it?.
What book was this in, and does it cover all XM models? sounds interesting.
D
