hydraulic fluid reservoir
xantia 19td 1984 hi all fluid reservoir leaking fluid from top. fluid replaced,filters replaced,new rubber seal on top of reservoir replaced,level ok (not over filled)[?]any ideas guys many thanks pete
Mine is just the same. I think it is only the seal at the top that doesn't seat very well. It can't overpressurise because there is a breather, and the top doesn't sit on tight enough to hold pressure. I believe it is the fluid slopping around inside and finding its way between the housing and the seal. It only shows as an oily patch, and has never shown any signs of losing a significant amount of fluid. Annoying though.
