Can anyone tell me what the specifications for the crush washer on the sump plug are? Diameter? Also, what torque should the plug be fastened to? My mechanic is a bit dodgy, I took the car in for an oil change and I am pretty certain he reused the old oil filter, so I have decided to do my own work from now on.
Thanks in advance.
Xsara Sump Plug Crush Washer
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
The sump plug is 14mm. Use a new crush washer tightened to 15 lbs. To use the old one you run the risk of stripping the thread on the sump. Pity Citroen didn't think to put the Xantia's access trap in the lower engine cover. It's a real bind having to remove it to empty the sump.
I've just noticed you have a petrol engine - I was talking HDI - but probably the same size.
