I am having trouble finding purchase - according to searches on this site, they're T30.
Are they "tamperproof" Torx, or do you just have to hold the driver at a funny angle?
Wanting to install the steering angle sensor.
Thanks, Adam.
Driver's Airbag Screw Spec (Xantia)
- My Cars: BX 1.6 TRS 8V 1989 Graphite Grey (Went to scrap)
Xantia 2.0i 16V, 1998 auto, Non Hydractive, Green (stands as donor)
Xantia 2.0i 16V, 2000 auto, Hydractive, White (dove)
C3 1.4 HDI, 2005 sensodrive, Lucia Blue
Xantia 2.0i 16V, 1998 auto, Non Hydractive, White (Haven't name yet)
Xantia 2.0i 8V, 1999 TURBO Activa, Silver Grey (Neil)
Xantia 2.0i 8V, 1999 TURBO Activa, Silver Grey (Heather)
Hi Adam,
I had the same problem, and I used a small piece of a mirror. Do the same to find the right angle and you will insert the driver in the hole more easily !!
Yiannis
Yiannis
BX 1.6 TRS 8V '89 Grey
Xantia 2.0i 16V, '00 auto, Hydractive, White (dove)
Xantia 2.0i 16V, '98 auto, Non Hydractive, White
C3 1.4 HDI, '05 sensodrive, Lucia Blue
Xantia 2.0i 8V, '99 TURBO Activa, Silver Grey (Neil)
Xantia 2.0i 8V, '99 TURBO Activa, Silver Grey (Heather)
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
It was somewhat fiddly, but all good now. The airbag/horn pad was all but impossible to perfectly align with the relief in the steering wheel (as before removal). Nothing serious, but enough to cause passing vexation to the fussy!
Hardest thing I found, was undoing the mounting catches for the clockspring connector plugs, on the column further down. At least I know now, should I ever want a steering wheel with radio controls on it, that the extra wiring runs far as the clockspring connectors but not the unit itself...
Thanks for the advice and encouragement.
Cheers, Adam.
Cheers, Adam.
