Wondering if anyone can advise.My car knocks when going over bumps on any surface.It is a type of vibrating knock.I thought it may have been a ball joint or track rod end. I had my track rods done, but the knock is still there. Local Citroen dealer is unable to locate problem.Can anyone help?
Knocking from My Xantia 1.8i 8v (R reg)
Rattly front brake pads? Failing that, I once got caught on a BX with a worn rack end on the steering. It's a ball joint type of thing & can only be detected with the car up in the air & the wheel off the ground. It is attached to the steering yet you can't feel it through the wheel; it can be very hard to detect.
Alan S
Alan S
Dave,
The reason I mentioned the rack end was that I bought this car from a Citroen mechanic (it was his wifes car), he in turn had it RWCd (MOT) by a guy who knew Cits, I looked for this noise for 22 months and it took a non Cit garage to pick it in straight away when he did the RWC on it when I sold it.
I've since found it in a couple of others; common rattle rarely found.
Alan S
Alan S
