Hi, I am trying to find out the PSI created by a 1.9TD bosch diesel fuel pump does anyone know please?
thank you in advance.
regards Nigel.
Bosch diesel fuel pump running pressure?
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
The injectors have a brake presur of 175bar and the pump should produce around 250bar (I think).
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
- x 24
Thanks Mark,
does this vary with engine size or are the pumps all a standard size for every single engine?
regards Nigel.
regards Nigel.
They are engine dependant. That is a bigger engine has a bigger pump , or an engine with more cylinders has a different pump , it can be different from one make to another , even the same car with the same engine can have different pump fitments. Like the 1.9TD can have Bosch or Lucas pumps.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 24
if the tank has an electric pump in it have you any idea what the pump pressure should be to feed the engines fuel pump please?
regards Nigel
regards Nigel
- x 24
