Hi all.
Recently bought a 2001 (51) 2.2 HDI Exclusive Diesel. Car sailed through the MOT which was a nice surprise!!
However the One problem I do have is with the turbo (or so I have been told)
When accelerating I get a loud noise from the engine, sounds like compressed air escaping? A friend of mine said it could be the pipe between turbo and engine is split?
any ideas if this may be the case or not?
also some tips on how to find the turbo and what it looks like would be very helpful! Remember you are dealing with a complete novice here!!
Citroen C5 Turbo Problems??
- My Cars: not applicable
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Assuming your C5 has done a fair mileage for its age, the turbo is almost certain to be leaking some nice black engine oil into its air flow. So the way to find and air leak is to look for an oil leak while tracing the inlet air-path from the air-cleaner to the engine:
The turbo is down the back of the engine - follow the pipery from the aircleaner into the centre of the turbo-charger's compressor (vaguely snailshell-shaped). The hot compressed air comes out where the snails head would be. The pipe from there goes to one side of the inter-cooler (an air-to-air radiator) usually mounted in front of the coolant radiator. From the other side of the inter-cooler the cool compressed air goes to the inlet manifold.
The oil will be coming out as a fine mist in a blast of air; the leak will be facing whatever is receiving this blast. You may have to clean up the engine to work out where the leak is - guaranteed to be somewhere you can't actually see!
Best of luck
Guy
Best of luck
Guy
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
