If you've got the engine out, or are doing strenuous stuff behind the engine, watch out for the fitting where the hose is attached to the back of the water pump housing:
It's made of brittle plastic and costs £25 from Citroen .
And would be a complete ****** to get out with the engine in-situ as you can't see it or get to it. Not too bad with the engine out, just an unnecessary expense.
Cheers
Jonathan
ZX water pump housing cover - Beware!
If Stupidity got us into this mess, then why can’t it get us out?
51 Clio 1.2, 01 Avensis
Water pump rear cover
Malcolm,
Nah, pixies came and did it when I stopped for a tea break....
Cheers
Jonathan
Cheers
Jonathan
