Berlingo - drips from internal light???
Post Reply
PeteH
My Cars:
Contact:
Post by PeteH »
Has any-one suffered from water dripping from the front center internal light, the one just above the rear view mirror. I have not had time to investigate yet but it is directly below the roof arial fitting so that will be my first port of call.
But any advice is welcome if you have already been there and done it. :)
Keep it up!
My Cars:
x 92
Post by citronut »
first thing to do is remove the aerial put somesealant under it and refit it
regards malcolm
PeteH
My Cars:
Contact:
Leaky Berlingo
Post by PeteH »
Thanks mate, thats a big help.
Keep it up!
oscarloco
My Cars:
Post by oscarloco »
citronut wrote:first thing to do is remove the aerial put somesealant under it and refit it
regards malcolm
I agree, I haven't seen it but I know there is a gasket there. Of course, with time, rubber gets hard and is easily cracked.
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
PeteH
My Cars:
Contact:
Drip Drip.
Post by PeteH »
OK, but you are only telling me what I already know, what I want to hear is, 'Yes I had this problem and I cured it by...................'
Or at least if you say remove the arial then give me a clue how to do it if you have already done it yourself.
Expecting rain tonight so have had to place a container underneath to catch the drips............ :cry:
Keep it up!
Ross_K
Lexia Available: Yes
My Cars: 2009 Citroen C5 VTR+ HDi 1.6
2004 Toyota Prius
2004 Alfa Romeo 156 1.6 Twin Spark
x 110
Post by Ross_K »
If you pry the roof light and/or console out you'll see the nut holding the antenna in place.
Loosen nut, lift out antenna, wang in a bit of sealant or cut-up bike inner tube.
Refitting is reversal of removal, etc.
PeteH
My Cars:
Contact:
Leaky
Post by PeteH »
Thanks for that Ross, have you had water leaking in via the arial mounting? If so have you any hints on how to 'pry out' the roof light, or remove the console.
Keep it up!
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1204
Post by Peter.N. »
..or even a liberal coating of Waxoil.
Ross_K
2004 Toyota Prius
x 110
Re: Leaky
Post by Ross_K »
PeteH wrote:Thanks for that Ross, have you had water leaking in via the arial mounting? If so have you any hints on how to 'pry out' the roof light, or remove the console.
I just used a flat head jewellers screwdriver in the gap between the light and the surrounding plastic. The light should lever out quite easily.
PeteH
My Cars:
Contact:
Leak
Post by PeteH »
Thanks for all the tips on stopping a leak at the arial/roof join.
The question is - has any-one ever had a leak entering here and did it run down the internal light and drip into the two cup holders in front of the gear stick. Or was the water entering from some-where else???
Keep it up!
My Cars:
x 92
Post by citronut »
well there is only one way to find out, you can ifndbut all day,
regards malcolm
PeteH
My Cars:
Contact:
Leak.
Post by PeteH »
I apologise profusely, I thought the forum was here to help each other.
Yes I could rip it apart to see if its leaking but why do that when the answer may lay in this forum.
Keep it up!
Ross_K
2004 Toyota Prius
x 110
Re: Leak.
Post by Ross_K »
PeteH wrote:I apologise profusely, I thought the forum was here to help each other.
No need for the sarcasm.
Check the seal on the antenna first of all as it's an easy thing to do.
Does the water in the cup holders taste like water, or is it bitter/funny smelling?
My Cars:
x 92
Re: Leak.
Post by citronut »
im sorry if you took my coment the wrong way, but that is a fraze i use all the time with my lot indoors, and i cant see any other way to tell you about your leak
ps whoooops clicked the wrong quote button, it was ment to be for the last reply from PeterH
kind regards
malcolm
PeteH
My Cars:
Contact:
Leak Fixed
Post by PeteH »
Many thanks superloopy1, your advice was spot on and the job is now done. Once I could see the 'interior' of the roof where the arial fixing came through it was obvious that this is where the water was entering. :)
Very sorry Ross but I miss understood your term 'rooflight', I thought you meant the glass panels in the roof, or the job would have been done sooner. :( If the water had tasted 'bitter' what would that have signified? :?
This is a great forum.
Keep it up!
Post Reply
