xantia 1.8 runs when you have dis/re connected crank sensor
Car will spin over well on starter motor, but doesn't fire. If you disconnect the crank sensor and reconnect it, it goes. It doesn't describe that as a regular starting procedure in the handbook. What can be wrong, apart from a bad connection at the sensor?
