Clutch Adjustment Citroen Saxo.
I recently added a Saxo 1.5 D to the household (for the wife) anybody know what is the correct clutch adjustment on this model - the clutch pedal seems to be far below the level of the brake pedal.
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Measure from the top surface of the pedal to the floor. Press the pedal to the floor and again measure from top surface to floor. Take 2nd measurement from the 1st and difference should be 130mm +/- 5mm. If it isn't carry out adjustment at the lower end of the cable.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
rule of thumb is about level with the brake pedel, or untill it gose into all the gears smoothly, or at least as smooth as an AX can, if the pedel has to be very high in order to alow selection of the gears it means you clutch is on the way out
regards malcolm
ps.
if you need a brand new engine (not recon) i have one for sale, very resonable price of around £750 OVNO
regards malcolm
ps.
