Veg Oil MPG.
- My Cars: not applicable
I can't say what caster does in real diesel engine but in model engines it gums things up pretty quickly if you don't take care (after run oil etc.). Also these machines only run basic carbs not precision injection systems. Is caster acidic when burnt? Whether such a small amount would affect a big engine I don't know.
How does caster break down veg oil? Sounds interesting if true.
Steve.
Steve.
not applicable
Industrial castor oil
Vegetable oils, due to their good lubricity and biodegradability are attractive alternatives to petroleum-derived lubricants, but oxidative stability and low temperature performance limit their widespread use. Castor oil has better low temperature viscosity properties and high temperature lubrication than most vegetable oils, making it useful as a lubricant in jet, diesel, and race-car engines. However, castor oil tends to form gums in a short time, and its use is therefore restricted to engines that are regularly rebuilt, such as motorcycle race engines.
The lubricants company Castrol took its name from castor oil.
PostPosted: Fri Apr 2008 Post subject:
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
I thought it was linseed oil that gummed up your engine, as a teenager I picked up a container of linseed and put in my moped and that well and truly gummed it up , I had to do a stripdown and clean tha varnish off of my rings Ive not any problems with castor oil though and Ive done thousands of miles on a teaspoon a tankful.
I have even heard they use it in germany when burnning veggie oil in their cars.
Perhaps mine doesnt gumm up because I clean the injectors by filling the filter housing with cleaner twice a year?
It may only affect two stroke engines who knows? then again two stroke model aircraft engines burn a percentage of caster oil as a lubricant I cannot say that any of my OS two stroke glow engines ever got really gummed up and the other bloger metions we use after run oil to lub the engine when not in use to save gumming up from happenning. I think the amount of castor used is offset by the fair amount of veggie oil used both have lubricating properties and so does diesel to some extent perhaps the balence is just right?
Kind regards Nigel
regards Nigel.
Kind regards Nigel
regards Nigel.
LOL at nearly 80mpg and LOL at a teaspoon of castor oil. Nuff said.
2003 Ford Mondeo ST220
2002 Ford Fiesta Zetec S
2001 Ford Puma 1.7 VCT
2008 Ford Transit Mk7
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
Re: Veg Oil MPG.
falling-out-with-my-car wrote:sorry youve lost m,e ther who mentioned 25MPG?.
falling-out-with-my-car wrote: I have noticed that deisel is not going the distance anymore a full tank of diesel goes about 300 miles or so which is rubbish, .
You did! Do the mathfalling-out-with-my-car wrote: i assumed the tank was 55litres 12.2 gallons .
I'm sorry Nigel, but your 80+ mpg figure is just not possible. Are you sure that your speedo is not recording km rather than miles.
Gammy
- x 24
Gammy,
as I said it has been very difficult to duplicate these conditions again accurately, the figures derrived from a 30 degree temperature day to scotland and back again ie a heatwave, that is why I said that I reckon atmospheric conditions affect the economny of the engine.
It has been inpossiable to duplicate these condition owing to the british unreliable weather and driving such a long distance in one go.
This is definately not acheieveable urban driving although I have to admit that veggie/diesel mix does give me better milage than plain diesel alone.
never mind it gives you lot something to chew over doesn't it.
Regards Nigel.
Regards Nigel.
Just thought I'd jump in here although it is slightly OT from the original post, so apologies for that. I have just bought a Xantia 1.9td and took it on a decent run over the weekend. I stuck it at an indicated 80-85 mph (sat nav said 77-82) and over about 230 miles I averaged 40mpg. Is this about right would you say?
My intention is to run a Veg mix once I've established how well (or otherwise) it works on Diesel.
Edit: btw, my user handbook says 65 litre tank
- x 24
Penguin,
Firstly remove the cat and exchange it for a front pipe of an older car (if it has one) burnning veggie mix will destroy it eventually.
Then check if you have a Bosch fuel pump, then go on to ebay and buy yourself a stanadyne fuel heater, you will see that their is a plastic connector connecting the fuel line together in the fuel line that leads to the fuel filter, insert the stanadyne heater in where the plastic conector has been removed from.
Buy yourself a 12vdc remote from Maplins because you wont want to go to your car and flick a switch in the coldest of weather. esspecially in the winter in your underwear, put an led inline so you know its on and off. Mines mounted in the plastic trim strip below the headlamp.
Add a couple of litres of pure clean veggie and run the car for a week if it seems ok add a gallon next week 4.5 litres, if that seems ok add a little more until you get up to your preferred ratio 50/50 or less or more.
60/40 etc. the higher the ratio of oil the more problematic your starting will be you nmay need to turn the key twice and heat the heaters twice.
on days when the outside temp is below 10 degrees C switch on yur stanadyne heater 15 Mins before you go out, It has a thermostat on the heater so it will switch off automatically once it reaches 10 degrees C but once you have started the engine the best bet is to switch it off it will drain your battery esspecially if left on all night long.
The Stanadyne heater heats the fuel in the fuel line sufficently to reduce starting problems with a mix of 60% veggie and 40% diesel.
Oh! and you will smell chips.
It is illegal to use veggie oil in your vechicle without registering with the tax office and paying tax on any road fuel you burn but the tax office trust us to declare the amount used so you can tell them you use 15 Litres a week to do your bit for the planet, hopefully you'll understand.
the tax makes veggie almost as expensive as diesel.
Opaying 1500 pounds for a conversion is not necessary and doesn't pay for itself for at least ten years.
Regards nigel.
Regards nigel.
Thanks Gammy, I realised I was running faster than optimum but reading some of the posts on here I was thinking that 40 was a bit crap!
FOWMC, Thanks for the info. I have been doing a fair amount of research into this for some time and all advice is added to the (sometimes conflicting) pool of knowledge. I can certainly confirm the prescence of a Bosch pump, my one pre-requisite for buying this particular Xantia. I have read with interest and disappointment at the inexorable rise in the price of virgin Veggie but Myself and a friend have managed to source some reasonable quality used veggie from the local pub/restaurant and are also on the lookout for more. My friend is in the process of setting up a centrifuge based cleaning system for said WVO and hopefully this will prove successful.
Cheers all and I look forward to more help/banter from this newly discovered forum.
- x 24
Penguin,
buy yourself a diesel hand pump that fits into an oil barrel and go to any Kentucky fried chicken outlet , they have to pay around £10 a barrel for their veggie oil disposal costs they will gladly give it to you for free.
Steve Wright on the radio does this in London he has rubber lined several collection vechicles for the collection and production of bio diesel. he announced a couple of weeks ago that one of his vechicles sprung a leak.
Personally cos I have the space I am eyeing a bio diesel producing kit at the moment but the ethonol adative is quite expensive.
Regards Nigel.
Regards Nigel.
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
There is no duty to pay if it's for personal use and does not exceed 2,500 litres per year. Apparently the HMC&E were not able to administer the vast amount of paperwork they were facing so they got the laws changed as above.falling-out-with-my-car wrote:It is illegal to use veggie oil in your vechicle without registering with the tax office and paying tax on any road fuel you burn but the tax office trust us to declare the amount used so you can tell them you use 15 Litres a week to do your bit for the planet, hopefully you'll understand.
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 97
I noted that the price of veg oil has gone up severely here in the last month. I found the Sainsbury stuff was best value if you got the 3l bottles (something like 72ppl) it's now about 95ppl.
Last week in Lidl, it was 79ppl but yours truly waited until last night to go back only to find that their cheapest is 95pence per liter.
I feel it's just increasingly less worth it. Maybe best to approach an establishment of deep fried food now....
Does anyone have experience of the filtration process? how it should be set up and how long it takes?
Graeme M
- x 24
