Hi guys,
Need to remove the airbag/steering wheel from my Xantia, do i need to disconnect the battery for a short while or will i be ok?
I also need to replace the keyfob, the rubber was getting tatty but the dog decided he would remove the rubber completely this morning, if i get another keyfob is it easy to reprogram?
Gareth
Airbag removal and key fob replacement
2003 Ford Mondeo ST220
2002 Ford Fiesta Zetec S
2001 Ford Puma 1.7 VCT
2008 Ford Transit Mk7
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
The keys internals are fine but the rubber cover over the switches doesnt exist anymore hence reason for replacement.
I only needed to remove the airbag and wheel to fit my Activa wood trim but i found a way around it
I got hold of a much better key, buttons in mint condition, but how do i swop the actual key bit over?
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 825
The rivet that holds the key is made in two pieces that join in the middle. You can insert a suitable tool, such as a blade or screwdiver, between the key and and the case and ease the case apart by a mm or two. This should split the rivet, which can then be flicked out with the blade. The rivet can be re-used.
Spot on. I now have a key without exposed microswitches!
