Hello.
I recently tried to drive through a flood in this car and managed to suck water into the engine. After recovery the engine is running again but smokes badly and is down on power.
I am thinking of changing the engine. My car is a 1992 with the belt driven vacuum pump. Ideally the replacement engine will have the same arrangement but if necessary is it easy enough to fit an engine with the camshaft mounted pump? Does anybody know what extra work / bits are involved?
Thanks in advance.
Alan.
ZX 1.9D (non turbo) engine swap.
ZX Diesel 1992.
Peugeot 205 1.1 1990.
Re: ZX 1.9D (non turbo) engine swap.
whereabouts are you? i know someone about to sell/scrap a zx with a good engine in it in the kent areaalanshep wrote:Hello.
Thanks in advance.
Alan.
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
