Hi Guys,
As you know, the Activa and V6 are "special case" models so it could well be that the sensor is in a different location.
citrojim wrote:My Activa seems to have one, a black box buried down in the depths of the subframe close to the ARB, but having no apparant physical connection to it, on the drivers side not that far from the height corrector.
That sounds like the "body movement" sensor - it's somewhat to the right of the height corrector and clamps onto the rollbar with a familiar clamp, and has an electrical plug - if yours doesnt have this, maybe someone has removed it!!
I can't say it's in the same position as yours Simon, from your description as there is no way I'd get at it from the wheelarch. Perhaps the Activa is a bit different.
Sorry I didnt get a picture of it... but rain was threatening and I was in a hurry.
It may well be in a different location on an Activa.
I presume it's an inertia (or g) switch, the contacts closing on heavy deceleration? Or am I confusing this little unit with the sensor that is attached to the ARB to measure lateral acceleration
You're confusing them both.
The body movement sensor (attached to the rollbar) only detects vertical front suspension movements - such as hump back bridges, speed bumps, and imminent suspension bottoming and switches to firm mode. It doesn't detect roll.
The switch I'm talking about connected to pin 11 is a hydraulic pressure switch - it's connected to the front brake supply line between the doseur valve, and the ABS block, and looks like a K shaped 3 way hydraulic union with a plug connected to one end.
Below 35 bars its closed, above 35 bars it goes open circuit.
Regards,
Simon
